Core drills
View the thread, titled "Core drills" which is posted in Plumbing Tools on UK Plumbers Forums.
Riley
Subscribed
Alright my plumbers from another mother
Know it’s been asked before but what core drills are people using. I need to bite the bullet.
Fair enough. I suppose it depends what former you have. To be fair mine was an impey, which you screw down. So I horsed out plenty of material then set it on sand cement- screwing down into sub base the following day .
Membrane down and good to go, mind you I cheated by advising custard so I could tile in 2” squares which follow the former nice and easy with no cuts!
Stop waffling me, waaaaay off topic.
It was a rigid foam one. Nice when the tiles are small enough for no cutting. I always try and push the customer to a small tile in the wet area. I tell them it gives better grip under foot with the extra grout lines.
Oooo the fibs we all tell to make our lives easier!
I agree, I had a punter asking me about nonslip treatment as they’d had a wet room done where the shower was basically 2 800x800 polished porcelain tiles split from the corners and was link an ice rink.
Marcrist DDM1 core drill thoughts or reviews please lads
I looked at this as a replacement to the Makita I have. It looks identical to the Milwaukee, even has the same case but is just a little less on the power front. I would imagine it is a pretty decent drill. We use the Marcrist core bits and dust extraction kit which both work well and make life a bit easier.
Thanks buddy I was thinking the same and I found a really good deal on it so I’m thinking it should be ok. I don’t do site work so am usually only drilling flue and condense per install rather than kitchen and bathroom as well. I have a friend that’s gifted me two big hilti cores too, only used twice but they’re 4” and 6” so need a decent motor behind it
Found a kit that comes with the extractor set for not much more £3-4 I think it worked out so I think it could be the winner
Just to follow up chaps. Bought the Marcrist DDM1. Used it for the first time in anger today drilling some really nasty hard red brick. What a machine, if I said it was like knife through butter I wouldn’t be exaggerating. Flue and condense drilled in under 10 mins. To be honest it would’ve been quicker but it took a while to change cores. Can highly recommend and can honestly say I don’t know how I’ve survived with an SDS for so long. Effortless drilling!!!
How were you with hard reds? I find they can sometimes clog the core and I have to keep cleaning the core on a scrap of concrete - but then the job is easy.
Learnt this the hard way, after burning out a core bit 🙁
I have a Marcrist and was loving it until it broke in less than 2 years. Love the slow start and general feel. Wish I had registered it. Can’t find anyone local in MK that will fix it. Might go back to Makita or try the Metabo
Have you had it apart and had a look, my corded Makita quita while back so i took it apart as nothing to loose.
It had a lot of overhead use and grit had fallen in the mechanism. Cleaned out, lubed up and to my constant surprise still going strong. Worth a try 👍
Reply to the thread, titled "Core drills" which is posted in Plumbing Tools on Plumbers Forums.
Riley,
WC1,
