View the thread, titled "Coring" which is posted in UK Plumbers Forums on UK Plumbers Forums.
derrybongo
Hi All
thought i might open up the subject of coring and the best tools recommended by yourselves. Also using coring bit or just roughing out the flue opening whats the more commenly used method.
With fluing and larger holes it's usually neater to draw a circle then use a 15mm (approx) bit and drill several holes around the diameter rather than a general mining job.
Reply to the thread, titled "Coring" which is posted in UK Plumbers Forums on Plumbers Forums.
