couple of questions about new boiler and gas cooker.
View the thread, titled "couple of questions about new boiler and gas cooker." which is posted in Boiler Advice Forum on UK Plumbers Forums.
B
becky4
hiya all i have been having a new boiler fitted it seemed to take three people to fit it and do the pipe work and it took just over 13 hours is thid right?
second of all we had some one out to fit our gas cooker 4months ago everythink was fine they didnt find a leak...after the guys fitted the boiler and moved and reconnected the cooker due to new pipe work the guy found an internal leak in the cooker now wouldnt he of found this the first time round and wouldnt we of been blown up by now if it had been leaking for 4months or is this down to them moving the cooker while doing the pipes?
thank you becky.
with the boiler every install is different n 13 hrs is not unusual.
as for the cooker a leak can happen at any time so thats y u people should get their appliances serviced n gas safety checked each year
Nothing like pointing the figure
The time taken to replace the boiler is quite acceptable, maybe even exceptional, You do not say the full work they have had to carry out maybe brought in extra body to speed things up to get up and running asap, see you have no complaints about the installation
As for gas leak, as said ,can happen any time and as leak internal to gas cooker, how can you even think about blaming the plumbers work, he would have done external pipework and that all Ok, maybe ring up the manufacturer and ask them why one of their 4 month old cookers have a internal leak
Think you should put kettle on ,make everyone a nice cup of tea and thank them for doing a good job of the boiler change over and being vigilant enough to locate and trace a gas leak on your cooker, making sure, you are not only warm but safe also
Unless there is more to the story
imho
i wern't pointing the finger just wonderd how common it is and if there was a chance it could of been the guy has he moved the cooker quiet forsefully.
well apart from the guy had two un gas safe peoplethere to help him and i thought dodgy of them and my landlord.
Reply to the thread, titled "couple of questions about new boiler and gas cooker." which is posted in Boiler Advice Forum on Plumbers Forums.
becky4,
becky4,
