I wonder if you can all please help me I have my gas exams coming up but would appreciate some clarification on a couple or four things!
1) when working our a gas rate on a boiler - do you compare it to the boiler input or output on the boilers plate/badge?
2) What is the tolorence in the readings between calcs from gas rate and boiler plate/badge?
3) When working out the gas rate on a cooker where normally is the badge/plate?
4) When working out the working pressure on a boiler, if that confirms correct pipesizing/gas etc do you have to put on all other appliances on full blast whilst doing the test?
Thanks!
Thanks!
