Crack in overflow pipe
View the thread, titled "Crack in overflow pipe" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Hi
I was hoping for some advice for a non-plumber! I live in a flat in a tenement building in Edinburgh - there is an overflow pipe emerging from the wall near the top of the building which has been constantly dripping for some time. It has been difficult to find out which flat the pipe is connected to but a plumber has been round to the top floor flat to the left of the pipe in the picture has said it is from that flat and it is due to a crack in the overflow pipe (I have heard this second-hand from the letting agent so no more info). It is c70ft off the ground so will need scaffolding to repair it which is a pain as it is causing problems in properties below.
But I don't understand how a crack in the pipe can lead to water constantly dripping out - surely there is an issue with a toiler/boiler in the flat that is causing water to end up in the pipe in the first place?
thanks in advance for any help!
It’s a pressure relief pipe of a boiler if the system pressure gets too high it’s comes out there they don’t reseal the best so could be passing
best to ask which one is topping the boiler up daily
tbh them flues need sealing externally to the building eg no gap/ entry
Thanks Shaun, the plumber said it is definitely the flat to the left of the picture. What I don't understand is the relevance of a 'cracked pipe' referred to by the plumber. Surely the water shouldn't be in the pipe at all if there is no boiler fault/plumbing issue in the flat?
It's possible that the plumber could have said to the letting agent something like "...the pressure relief valve is open a crack and causing the 'overflow' to drip." and this has been garbled in transmission to you. Best to talk to the guy directly if possible.
I suspect the plumber actually said to the letting agent something like "...the pressure relief valve is open a crack and causing the 'overflow' to drip." and this has been garbled in transmission to you. Always best to talk to engineers directly if possible.
Thanks Chuck - yes, always better from the horses mouth! But they said they need scaffolding to access it so if it was the valve surely they could do that internally. What I don't understand is why that overflow pipe should be constantly dripping - surely a constant flow of water shouldn't be in the pipe in the first place whether it's damaged or not?
The only reason they would need scaf is to cement up the flues I would ask for it to be written down what’s wrong from the engineer
The only thing which occurred to me is if that overflow pipe did need replacing (and is cemented in) you would have to perhaps access it from outside?
its not an over flow as has been stated its the safety blow off pipe from the boiler so no need to work from outside the flue does need sealing though.
the pressure relief valve needs replacing and possibly the expansion vessel (this may need just repressuiring) but will need to be checked
Thanks - presumably the sealing of the flue does need to be done from outside? Although that would mean installing a new boiler in an upstairs flat round here would be very expensive....
Reply to the thread, titled "Crack in overflow pipe" which is posted in UK Plumbers Forums on Plumbers Forums.
NorthernLight,
NorthernLight,
