as the title says, can you repair a crack in an acrylic bath? The bath in question is cracked an inch or so up from the bottom of the tub, at the end where your feet would go. It caused a little bit of damage, bit of water came thru customers ceiling, but not too bad. The customer temporarily repaired the bath with some sealant which worked for a bit, but has had to re-apply it recently as it has not held up.
Im not too sure what the customer used, the crack is about 3 inches ling and is just a crack, there is no open hole and no pieces missing, the customer is not too concerned about aesthetics but just wants it watertight obviously.
I have never came across a similar problem and was just wondering can the bath be repaired or is it a new bath jobby?
Any advice much appreciated.
