Thoughts on this please:
System boiler, glowworm floor-standing, old.
Two two-port valves.
3 story property.
Drained down for rad change. Re-filled - got quite bit of air stuck in system.
Back-filled by connecting cold in to f+e to the vent. Back-filled a bit, went round and bled a bit, back-filled some more - until got water out of every rad.
Fired her up. Flow gets red-hot as far as (but not including) pump. After another 10-15 mins or so the pump itself gets hot and the pipework directly after luke-warm. Give it another 10 mins and another 6 inches of pipe work gets tepid - but this is the maximum.
There is power to the pump and it is spinning, pump is bled. Pump valves are open. Port valves open.
Thought maybe blockage so drained down again and refilled. This time giving pump the old on-off as it filled to swirly things around a bit. Lots of air going round the place. This time rads filled on their own and bled well without any back-filling. System full.
Turned her back on - exactly same problem.
3 story property.
