Stoo75
(Thread should say 'Curious Problem' not 'Curious Plumber'! Sorry)
I have a Baxi MegaFlo 28 HE boiler with an Albion unvented indirect cylinder in a pretty standard 1930's semi.
The problem, basically the Central Heating comes on for a while (maybe 30-45mins) then the boiler stops firing, however it comes back on when the hot water is active. It's enough to heat the house especially after a couple of baths as that seems to trigger the central heating. If the CH system has been off and is cold, clicking the override kicks it into action, after that nothing unless the hot water it on.
Observations:
The CH programme is on
The thermostat is on and calling for heat (up high to try to keep it going)
The motorised valve on the CH is open
The boiler has recently been serviced and seems to be working fine when it is initially on and also when heating the water in the cylinder.
Could it be the boiler tripping out somehow (i am totally ignorant on how they work) but i'm guessing there is some sensors in it that read the water temperature and fire up when the thermostat calls for heat?
It's driving me mad as i have can't seem to get to the bottom of it!
Any suggestions would be great, i am not planning on fixing this myself but would be good if i could point a plumber at the source of the problem without wasting anyones time.
Thanks in advance!
Observations:
Thanks in advance!
