View the thread, titled "cutting roof tile for flue" which is posted in UK Plumbers Forums on UK Plumbers Forums.
N
newbie1
ok guys following on from a previous thread boiler job has old single wall flue with roof termination so i need to fit new boiler and take flue out the tile using an upstand
now what do you use to cut the hole in the tile for flue??
answers on a postcard please
A Roofer! 🙂🙂
Depends what the roof is. If its modern concrete tile a whizzer( angle grinder). If its slate, a slate knife and slate hammer or angle grinder.
And a lead slate made to the roof pitch or a bought rubber one.🙂🙂
tks bernie angle grinder looks best bet and then a lead upstand/tile
i hate roofs but lucky its chalet style and has a flat roof close enought to stand on
Yes Justlead the old lead slate and upstand with a neoprene collar to seal the top of the upstand around the pipe, takes some beating doesn't it?
Hi Bernie. On occasions and odd sized flue pipes a weathering seal can be made by cutting a band from a disused inner tube, readerly avaiable from tyre shops.
Reply to the thread, titled "cutting roof tile for flue" which is posted in UK Plumbers Forums on Plumbers Forums.
