View the thread, titled "Cutting spil pipe below wall level." which is posted in UK Plumbers Forums on UK Plumbers Forums.
G
GNA
I need some advice here - fitting a new soil stack (plastic) and to avoid the use of spacers under the stack clips ( and thus having the stack a long way from the external wall) I need to cut the pipe coming from the WC about 45mm below the level of the external wall brickwork - how is this best achieved?
Gareth
Are you saying that you want the 4" bend to the WC partly in the wall..?
If so when you diamond drill the hole make it bigger to take the internal radius of the bend, or elongate the hole.
Yes the pipe is already in the wall and cut flush to the external wall surface.
I dont want to set the bend in the wall - I just need to somehow cut the pipe about 20mm below the wall surface as if I dont the bend will push the soil stack too far from the wall and need spacers behind the soil stack brackets.
I cant take up the floor to fit a new run from WC to wall.
You could use a small disc cuter that fits on your drill allowing you to cut soil pipe from inside to out in the wall recess, you can get these attachments from a good tool shop or you may find bremel would do an attachment,make sure you make round inside of soil pipe were you want to cut and follow line
Ps little tip of subject
I have a small bremal with a cutting attachment I use to cut off the locking nuts on the cistern plate on c/c w/c's when all corroded and central heating pump nuts
Thanks everyone,
Used a dremmel in the end (well a pro-power B&Q own version) with a small cutting wheel - cut the pipe like butter with no nasty burrs.
As an aside also just used it to slice some stubborn taps off underneath a basin - will keep it in my toolkit from now on !
G
Reply to the thread, titled "Cutting spil pipe below wall level." which is posted in UK Plumbers Forums on Plumbers Forums.
