K
Klarenza
Hi everybody,
I need to drain a small direct cylinder (second floor used just for hot water supply)to replace it but there is no drain cock. The gate valve on the cold feed pipe is jammed. I do not want to syphon with hose (to far from drain). I want to isolate and empty the water tank, open all taps, undo a nut on the gate valve and hot water oulet to release pressure. Is that ok?
Any other idea guys? Thanks a lot for your answers. 😉
