View the thread, titled "Cylinder stat or pipe stat? Best way" which is posted in UK Plumbers Forums on UK Plumbers Forums.
C
Cubbs
Evening fellas
been reading up on the green building forum. Suggested in there to wire in a pipe stat onto the return on primary circs instead of using a cylinder stat on unvented cylinder.
Would then the boiler boiler not fire so often when cold water enters the cylinder ?
thanks
That would be going against the manufacturers instructions. The thermostat supplied with the unvented unit is always to remain and be used.
Remember the thermostat is one of the most important safety parts of an unvented unit because overheat is the danger
as already said, everything that is supplied by the cylinder manufacturer must be fitted per manu fitting instructions
Reply to the thread, titled "Cylinder stat or pipe stat? Best way" which is posted in UK Plumbers Forums on Plumbers Forums.
Thread Information
Title
Prefix
N/A
Forum
UK Plumbers Forums
Start date
Last reply date
Cubbs,
Dotty,
