View the thread, titled "D2 from 15l under sink heater." which is posted in UK Plumbers Forums on UK Plumbers Forums.
This is what I found:
A suitable plastic pipe (such as polypropylene complying with BS EN 1451-1) supported at maximum 300mm intervals, may be used for downstream pipe D2. A maximum distance between clips of 300mm provides adequate support to the pipe D2 in the event of discharge from safety devices
Am I right in thinking though on a 15L water heater it only has a pressure relief not a temp pressure relief?
It isn't a d2 if its only pressure so no length or termination regulations. It would be like your boiler pressure relief
Over 15L it has to have a TPRV as standard
Yes 30l and above has both
No still can be temp as it’s pressure related
Reply to the thread, titled "D2 from 15l under sink heater." which is posted in UK Plumbers Forums on Electricians Forums.
