View the thread, titled "D2 plastic pipe instead of copper due to high cost." which is posted in UK Plumbers Forums on UK Plumbers Forums.
There's not much between them but this is what I use, always been very reliable.
It's priced very well too.
Remember your clipping distances if you use plastic pushfit. The regulations say when using Polypropylene to follow manufacturers instructions. It also suggests this is normally clipped at 300mm spacing.
Have a look at Tectite metal plastic tube with aluminium core you can bend it with a mini bender clip distances much greater than plastic can be used on hot water secondary circulating systems .
Need the dedicated re rounding tool though we have found it really good .
It's a good product in my opinion. It's rated to high enough temperatures to comply with D2 regs. However it only comes in 15mm and 22mm so if you need the D2 to reach further than 9 metres, minus bends/changes in direction, you need 28mm so you are back to using copper or pushfit waste.
It always makes me laugh about plastic discharge regs then they have plastic tundishes, most of the ones they send with the cylinders are c*** cheap rubbish, which IMO probably wouldn't last 2 minutes at temperatures over 100c - and most of them overflow over the sides too if it discharges at full rate! (Yes they did have 300mm below the dish 😂 )
Reply to the thread, titled "D2 plastic pipe instead of copper due to high cost." which is posted in UK Plumbers Forums on Electricians Forums.
