Guest viewing is limited
View the thread, titled "Daft Question Alert. Twin Wastes on a Bath" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Sorry guys but what exactly are twin wastes on a bath? Seen a bath advertise with these specs.
Now I'm used to baths with one drain plug and one waste trap but if a new bath has 2 wastes does this mean 2 plug holes and 2 waste traps under the bath are required?
As Gsmk1, seems to only be on some walk in baths, they may be in larger normal baths.
Yes 2 holes and traps.
Install instructions say either join both at a collector, (eg 50mm waste) or just join together, presumably they've been tested and found not to overcome a single 40mm pipe due to the restrictions at the bath wastes.
2 holes visible in below pic
Thanks Guys, it is indeed a walk in bath I was viewing. Due to the wife's health needs I have got to remove our existing bath and replace it with one of these so she can get into the bath.
So it would be ok to connect the 2 traps together via a T-Piece or yolk so I only have 1 pipe exiting the house ?
It won't be used as a bath as I already have a shower over the existing bath.
Reply to the thread, titled "Daft Question Alert. Twin Wastes on a Bath" which is posted in UK Plumbers Forums on Plumbers Forums.
Thread starter
Joined
Location
Staffordshire
DIY or Homeowner
Thread Information
Title
Prefix
N/A
Forum
UK Plumbers Forums
Start date
Last reply date
Thread Tags
Tags Tags
bath
maverick54,
maverick54,
