K
kingo
i have removed my broken danfoss 3 port valve as the ch was coming on with the hot water only, my problem is i have replaced this with a honywell 3 port .
and the wiring is slightly different , on the danfoss it has 4 wires ,,grey, blue,orange and (brown and white combined)
on the honeywell it has 5 wires ,, grey,blue,orange, white and (yellow green earth wire)
i have swapped all wires like for like at the terminal block, i have put the earth from the honywell to an earth point, and have put the white wire were the old white and brown wire connected to the block.
my problem now is the room stat will turn the heating on but it will not turn it off, the boiler will just keep running until it turns off on the boiler stat, and then will refire once it has cooled down.
so is the wiring different on a danfoss hsa3 do i need to do some thing different when wiring in a honywell ?
