Guest viewing is limited
Danfoss TS2
View the thread, titled "Danfoss TS2" which is posted in UK Plumbers Forums on UK Plumbers Forums.
M
MM10
Hi, I am new to this so apologies if this is the wrong forum for my question. I tried to log into the electrical but it wouldn't let me log in.
I have recently moved into a new house. The heating is controlled via a Danfoss 62057 time clock. This in turn is controlled via a danfoss TS2 remote stat. My new house is a 3 story town house and the time clock is on the top floor. I find a real pain to have to go to the top to turn the heating up/ down.
My my question is - can I change the TS2 for a bog standard dial type stat? Would this work or is there another way to control the heating from the ground floor.
Many thanks.
Ts2 is a remote sensor, you cant change it for a conventional stat.
They're used with TP timers
I cant find 62057 is that number correct or do you have a picture of it
Thanks, inside the cover it says - pn 62057. Having looked it up I believe it is a danfoss TP 9000. Hope that helps. Thanks.
Reply to the thread, titled "Danfoss TS2" which is posted in UK Plumbers Forums on Plumbers Forums.
MM10,
Unregistered,
