M
MikeH
I have a DeDietrich wall-hung boiler (model: CITY 1.24/II).
The water feed comes in via a valve, pressure limiter then T-piece with pressure gauge -- showing 2bar.
There is a pressure gauge on the outflow from the boiler to the rads/taps - also showing 2bar.
But the boiler itself shows only 0.5bar (red LED). I know the other (green) LEDs work, because they have a secondary function (re configuration).
So superficially, it seems to suggest the boiler's water pressure sensor or the sensor circuitry is faulty.
But curiously...
There are two small valves in the brasswork under the boiler, and the manual states that they should both be opened to top-up the water. That seems a tad strange; it looks like one is for topping-up and the other for draining-off if over-pressured (it leads to an overflow pipe) [see attached image]. Anyway, whether I open one or both of those, nothing happens - no hint of pressuring/inflow noise (OK - maybe it has equilibrated at 2bar) and no drain-out (oo - perhaps that low pressure LED is correct pressure?).
Any thoughts?
What is wrong, what to do aboutit?
Thanks for your thoughts,
Mike
But curiously...
Any thoughts?
Mike
