View the thread, titled "design approach for new shower" which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
I'm going to be installing a new shower. I have a combi. I won't be able to feed 2 showers from a single combi so I going to be adding a second combi just for this shower. I have reasonable pressure (6 bar) and flow rate of 16/l.min. In order to feed these combi's operating simultaneously, I need to ensure sufficient flow to each one.
Q. Do I have a single pressurised cold water tank that has 2 take-offs
Do I have 2 x pressurised tanks (for each combi)
Would an unpressurised tank suffice or will it absolutely need to be pressurised?
Is there another way?
No to the combis
change your system type either
gravity cylinder with a 80 gallon cold tank with a shower pump on the outlet to the cylinder
mains unvented cylinder depending on your mcw
Shaun you know this guy, he knows more than all of us put together and opted that brilliant Japanese boiler.
I added a 75l header tank which has a 22mm mains water feed and a 22mm outlet to the boiler intake. The result is that there is no drop in operational pressure and flow rate when other cold taps are turned on so the boiler does not reduce flow rates (it has set points for hot water which cannot be exceeded hence the sensitivity)
Reply to the thread, titled "design approach for new shower" which is posted in Showers and Wetrooms Advice on Plumbers Forums.
