Guest viewing is limited
"Designer" radiator inlet and outlet issue.
View the thread, titled ""Designer" radiator inlet and outlet issue." which is posted in UK Plumbers Forums on UK Plumbers Forums.
I've bought 4 new rads to replace existing ones. They are all singles and have inlet marked on lefthand side. The problem is that the existing pipework (microbore, plastered in-wall) has the inflow sometimes on the right and sometimes on the left. As the rads are singles I can't reverse them. It would be a real pain to replumb - floorboards up, replaster etc. What is the consequence of incorrect installation? Is it just an efficiency problem, e.g. it would take longer to warm up?
Normally they have a direction of flow due to baffles being in place to direct the water round. If they are not piped correctly the flow could just pass through the bottom without rising through the whole radiator. Could you not just hang them and if they don't heat up simply reverse the pipes under the floor for the affectedradiator?
Reply to the thread, titled ""Designer" radiator inlet and outlet issue." which is posted in UK Plumbers Forums on Plumbers Forums.
Hillabaloo,
Hillabaloo,
