View the thread, titled "Disabled tolets - What taps?" which is posted in UK Plumbers Forums on UK Plumbers Forums.
E
emergencyman
I have a basin tap to fit in a disabled toilet at a doctors surgery.
Its the basin mono type tap that moves left for cold and right for cold.
Do I need to fit TMV3 or I have seen a tap that can be set to limit hot water ( non thermostatic), would that comply with regs?
You can have a standard lever tap supplied from a separate TMV3 mixing mounted underneath the basin. The tap design must of course be suitable for disabled use.
Reply to the thread, titled "Disabled tolets - What taps?" which is posted in UK Plumbers Forums on Plumbers Forums.
