Went to fix a 'water leak' for homeserve. No water leak but boiler had been moved from downstairs and wasnt working properly. Owner/ son of owner/ told me this. Was about three degrees out from straight on the wall. Drop test went straight out so i IDed the installation and capped at the meter. They asked me back to find the leak privately and i informed them that i might have to turn off the boiler as they had obviously moved it themselves and it wasnt safe. They cancelled the appointment i presume to do it themselves or get someone else in.
My question mainly i suppose is should i inform anyone of the potentially dangerous installation a la RIDDOR? It sounds like this only works if you have an installer name or address.
Theyre obviously too tight to pay for things to be done properly although the bank account that qualifies them for homeserve means you have over 80k going in every year.
If they get a gas safe engineer in to find the leak theyre obviously going to have to recommission the boiler so will check if its safe, hopefully. Theyre the last engineer on site then. If they do it themselves then im wondering if ive done enough to keep people safe and if theres more i can do.
Thanks in advance.
Another part of my worry is that they may rent it out and not bother about cp12 or making anything safe. And i now feel responsible in some way although i feel i have followed protocol and have my signed id form.
Thanks in advance.
