View the thread, titled "DIYer installing WC" which is posted in DIY Plumbing Advice on UK Plumbers Forums.
M
Marco1976
I would like to know if I can put my 110m WC waste pipe into the connector show on the pic.
I am assuming I can take off the plastic bit and insert the waste pipe. Is this OK?
Also can the waste pipe enter the connector at a slight angle rather than straight? The reason I am asking this is that I need to clip the WC pipe to the wall and I am not sure the distance will be right to accomodate the wall clips if the pipe has to enter the connecto5r straight,.
thanks
That is a time saver coupling which is tightened/slackened with a torque wrench and has a rubber gasket inside it as a seal. Suggest you should get a qualified plumber to have a look who has experience in using Timesaver couplings.
They will take your plastic soil pipe, but on this ocassion you really do have to know what you're doing. Get a plumber in mate as it will save you costly mistakes later on.
Reply to the thread, titled "DIYer installing WC" which is posted in DIY Plumbing Advice on Plumbers Forums.
Thread Information
Title
DIYer installing WC
Prefix
N/A
Forum
DIY Plumbing Advice
Start date
Last reply date
Unsolved
Thread Tags
Marco1976,
Guest123,
