DIY'ER just called...
View the thread, titled "DIY'ER just called..." which is posted in DIY Plumbing Advice on UK Plumbers Forums.
mutley racers
Subscribed
he did all his own plumbing when building his house, now he is trying to sell his house and building control came round to check soil pipe is tight. It is not, has a leak. He asked if I could go and find the leak. are there any common places for these to leak? Like in the pump hose. i had this before and i did not check it for hrs. Went mad i did
BC won't accept any drop. They will want to see it steady at around 50mb for 2 minutes or however long they can be bothered looking at it.
As Ryan said, there are many simple ways to get around it if you have a think about it but you need to be there. Kinking the hose probably won't work unless the bc guy is a numpty. You need to think of more ingenious ways.
I once got a motorway service station passed testing 10ft of pipe from the manhole. Just think about it.
Probably more than half the drains in the country wouldn't take an air test
Oh right, I thought it had to be 38mb for 3 minutes. Ingenious ways, can you give a little more info than that. It's going to be a newly qualified BC. so they might not know the kink trick
Get rid of the pump and T piece. You don't need it and most pumps leak through the non return valve any way. Put the pressure up by blowing into it (gently) kinking the hose and sticking it on the gauge.
How much of a drop are you getting over about a minute?
Reply to the thread, titled "DIY'ER just called..." which is posted in DIY Plumbing Advice on Plumbers Forums.
mutley racers,
mutley racers,
