View the thread, titled "Do i replace my old Baxi Bermuda boiler" which is posted in Boiler Advice Forum on UK Plumbers Forums.
C
Cis4cookie
Just bought my first home and there's a baxi Bermuda 50/6 back boiler currently there, all working of course. Ive had many people tell me to replace it with a combi as it will be more efficient and I will be getting robbed using the current back boiler. My question is do I get a combi fitted or just keep the current back boiler, my sister also has a back boiler which has been going strong and hassle free for years and her bills are not insanely high like people say.
see how you get on after winter, for longer run you would probably save money on bills by getting new more efficient boiler. Note, i have nothing against some old boilers as they are good and reliable, unfortunately not as efficient as new ones.
had a lot of different opinions on this with regards to running costs and heard a lot of bad things about combis breaking and costing a lot to repair, I personally have no idea but currently renovating the home so if I was to fit a new boiler now would be the time to save any disruption in a year or 2. Really un sure what to do tbh
You don't have to have a Combi as a new boiler, if your Hot water cylinder is in good condition have a heat only boiler.
Old boilers can go on for years of they've been looked after, but you're right, newer boilers can have lower running costs. It will take a few years to get your money back through reduced bills, though. However, if you're renovating, then now is the right time to have the work done in my opinion. Why are you set on a combi, though? You have a Baxi Bermuda, so you already have a hot water cylinder - just upgrade to a modern system or heat-only boiler, and unvented cylinder. It'll blow the socks off a combi for hot water performance, and there's less to go wrong with a heat-only boiler..
well I had a few people look and they all said a combi would most suit the property, I was also told that a lot of fitters opt for that as its an easier install for them
It's also cheaper to install, there not a lot of difference between a system boiler a d a combi.
Nows the time to do it if your having a re furb.
There are load of different opinions on combi brands, stick with a well known brand. But nothing Italian or French.
Yes, it is easier to install, and customers like them because they free up space by losing the cylinder. But no combi will match the hot water delivery of an unvented cylinder. More expensive initially, but the performance will make up for that.
How big is the property? How many bathrooms?
Both choices depend on incoming supply and what customer needs are
Service the baxi, maintain it, don't cover up your ventilation with wallpaper and hang on to it as long as you can. It will outlive any modern boiler if its looked after. The running costs will be slightly higher but as dancin has said invest in good house insulation instead.
i would stick with your current vented cylinder if it was my house just get a heat only boiler , not seen anyone mention the pressure differencr tho on sealed system offering a possibility of a fitting going ping !
Thanks for all the quick replys guys, really helpful stuff. The house is a 2 bedroom 2 up 2 down fairly large rooms I suppose running 5 rads in total plus a small towel rail I intend to fit in the bathroom. Just about to insulate the loft before boarding out and planning to have the cavity's done also. With regards to the space in the fireplace around the current boiler can this be packed with insulation or do you have to leave it open around it.
Stick with the bermuda. Top boiler. But have it serviced regularly, the flue liner can't last forever.
Leave the fireplace as it is, you will have to disturb gas joints for that and will require a gas safe engineer for that.
also you would be causing a fire hazard!
my suggestion would be is to keep the back boiler and if you have concerns about hot water, check if you can have an unvented and if so have that installed and convert the system to fully pumped if it isn't already.
in the event the boiler goes pop in the future, just install a new boiler above the cylinder 😀
Noticed that there is insulation around the liner up the chimney, so this is why I wondered if insulation could be put around the boiler itself
Insulation & upgrade your controls, if cylinder looks old with the old type (Red) insulation jacket replace it! for more efficient cylinder, if you are stuck for space for a new boiler, look at the new baxi HE back boiler replacement, But it comes with electric fire.
How have you seen that? You have to take the fire front off to inspect it!
Had a gas engineer round to move our cooker pipe and I asked if he could remove the fire front so I could have the boiler possibly serviced but I wanted to gain access to the horrible fire surround to possibly replace it with some sort of tile or brick effect. depending on what the plan was
Reply to the thread, titled "Do i replace my old Baxi Bermuda boiler" which is posted in Boiler Advice Forum on Plumbers Forums.
