does a gas hob need a bayonet fitting
View the thread, titled "does a gas hob need a bayonet fitting" which is posted in Gas Engineers Forum on UK Plumbers Forums.
U
Unregistered
Hello,
In fear of having the wool pulled over my eyes, can somebody who can quote the reg. please comment on the following:
Ive just installed a new kitchen, the worktop has been cut for a gas hob. the outlet is on a valve, with a G1/2 Male connection, the hob also has a G1/2 male connection. I've asumed that a G1/2 FxF connection pipe, a quick test for leakage and secure the hob would be job done, but ive been told that I must have a bayonet fitting, and the outlet is pointing the wrong direction, so the system needs to be isolated and the outlet changed... sounds like a money spinner to me...
thank you.
Difficulty to picture what your on about but leave it to a gas safe engineer & it should all be okay... Otherwise register & load up a picture & we can comment
hi thanks for answering, the bottom question is. Does a gas hob have to be connected via a bayonet?
thanks for your comment, the advise that I must have a bayonet came from a gas safe engineer, but while I agree that might be nice, the question is, Do i need a bayonet fitting under the appropriate regulation? the existing valve with male G1/2 outlet seems perfectly adequate to connect a built in hob
if its built in (non movable) no bayonet fittings is required unless stated in mi's
thanks ShaunCorbs, I'll double check the mi's, and find another gas safe engineer who'll do what I've asked and doesn't start flowering up his quotation. The hob is fixed and non moveable into the worktop, hopefully It wont need touching for the life of the kitchen! cheers.
The hob requires accessible isolation valve and piping up in solid copper unless manufacturers instructions say a flexi hose can be used and said cooker hose can be fitted as normal. Ie. no strain, no chance of damage, temps kept below 70 etc...... If there is an oven underneath then you can not use a hose even if the manufactures instructions says you can due to the heat off the oven.
If you feel your engineer is talking nonsense then get another engineer in. Don't look for a cheap option pay the going rate and have it done correctly.
Installing a cooker is quite easy, knowing it won't kill the user and his/her family is the important bit, use a gas safe engineer.
Get a gsr in and trust his word and his training. Quite often what the customer wants is not legally permitted.
You've had more than enough information from us now. Go and register to receive more.
Reply to the thread, titled "does a gas hob need a bayonet fitting" which is posted in Gas Engineers Forum on Plumbers Forums.
Unregistered,
Dotty,
