View the thread, titled "Does a toilet cistern need to be screwed to the wall?" which is posted in Boiler Advice Forum on UK Plumbers Forums.
payvpac
Hi, can anyone please help.
I am replacing the toilet in my ensuite. I have noticed that the new toilet I have bought does not have any holes in the cistern to screw into the wall.
The question is, does the cistern need to be screwed in? (The base is attached to the floor via plastic brackets)
If it does need to be screwed in, can the cistern be drilled easily or should I get a professional in for the job?
Thanks in advance
Picture of w/c would be good,if a budget w/c always the possibility of holes missing however a lot of the smaller style cisterns do not need screwing to the wall and thus do not have holes for securing,they just sit bolted to the pan,that should be secured to the floor securely,you can stick a bead of silicon alone the top inner rim if you wish(do not put lid on till it dry's or could stick lid down also!)
The pottery is not as heavy as it used to be and the flushing technic is different now,you are just giving a small push of a button at top,exerting a gental central downward pressure as opposed to the old cistern flushes that you were pushing down with a downward side ways presure ,quite hard,this required cistern to be secured
You can drill a cistern or ant pottery quite easily with the right drill bit
imho
some dont even have holes to be screwed back with!!!!!!!!!!!!!!!!!!!!!!!!
thanks all, will try a bit of silicone. A budget toilet it is mind. Even the fixings that connect the cistern to the pan are nylon. Think I will go out and buy a decent metal screw fixing set so atleast the cistern will be connected to the pan securely.
modern small cisterns tend to be fine
Small line of silicone at the top of cistern,that way it can be easilly accessed and cut through if a removal is needed in the future
If there's no holes then it's a couple of dabs of clear silicone near the top (or where the screw holes would be) to help stabilise the cistern. These can be easily cut through in the future if it needs to be removed. Not like the one I had to take out where they'd used a full tube of silicone 🙂
A strip of good quality white double sided adhesive foam, the stuff used as draught excluder for doors and windows applied to the top back of the cistern, gives a flexible cushion and gives the right amount of space for the lid to fit snugly without it being tight to the wall.
Useful stuff too on bath panels and as a temporary seal at the base of bath shower screens that swing open due to the rubber seal being worn.
best get brass or a plated fixing that won't rust
Reply to the thread, titled "Does a toilet cistern need to be screwed to the wall?" which is posted in Boiler Advice Forum on Plumbers Forums.
