Don't forget to check the working inlet pressure!
View the thread, titled "Don't forget to check the working inlet pressure!" which is posted in Gaining Plumbing Experience on UK Plumbers Forums.
M
mike_s
Not that I did, but just thought I would mention it, after checking the inlet working pressure at the boiler hundereds of times without a fault, today I installed a boiler, inlet pressure 25mb, fire the boiler up and pressure drops to 14mb. So I check at the meter, 25mb standing, fire boiler up and drops to 18mb. gas rate at the boiler was also 34kw instead of 30.
So, after a quick phone to national grid, they came out and changed the meter governor. All pressures and gas rate instantly corrected, 19mb working pressure at the boiler and a 30.4kw gas rate.
Standard practice for me is working pressure at meter on first lighting the new boiler, after clearing air locks ect.
If low I know SGS will be out within 4 hours at the most, enough time for me to carry on with the rest of the works reqd. 🙂
Checking working pressures as the tools are being cleared up is a :banghead: if they are not correct.
I reckon on 50 % callout for new meter governors to be fitted when I install new boilers.
Reply to the thread, titled "Don't forget to check the working inlet pressure!" which is posted in Gaining Plumbing Experience on Plumbers Forums.
mike_s,
Kev the gas,
