So the lockshield valve on the left was boiling hot but I noticed the thermostatic valve on the right was cold, is this normal? Both valves I had to unscrew the screw to take the plastic caps off & they both had the lockshield type turn.That will drain the whole central heating system as well
Sorry what do you mean it is a lockshield valve? I know that normally one side is a lockshield & the other is a thermostatic but on this radiator when I took both plastic caps off they both had lockshield type spindles on both sides, only difference was the caps. As for opening the cooler one I did open it more but it stayed the same. I’ve had a check on my own radiator valves in my home & I also have a couple of radiators where the lockshield side valve is cold compared to the boiling hot thermostatic valves on the other side, so I was wondering if this was normal & supposed to be like that or a fault?That’s because it is a lockshield valve you tried opening the cooler one by 1/4 of a turn ?
Ah ok I’ve never come across ones with two lockshields before but these are old radiators so it makes sense. As for one valve being cold compared to the other being boiling hot, is that normal or is something wrong?You don’t have a trv on that rad just two individual lockshield valve
Ok so when I'm draining a radiator like this down normally you would count how many turns it takes until shut off on the lockshield valve side for balancing. Which side do I count the number of turns on this as they are both lockshield valves?Normal flow is the hot one colder one is the return
Last question, would it be normal for it to be more than that as when I turned the cold side it was open a lot more than 1/4?Cold side and normally 1/4 of a turn open
Reply to the thread, titled "Draining radiator?" which is posted in UK Plumbers Forums on Electricians Forums.
