Guest viewing is limited
Drayton digistat
View the thread, titled "Drayton digistat" which is posted in UK Plumbers Forums on UK Plumbers Forums.
C
ceabhail
Hi,I have a problem with our digistat ,there apears to be no signal being picked up by the SCR unit,the red light on permanently,have changed the batteries in the stat and the temperature is visible also the flame symbol.Do I need to recommission the digistat R.F system or is there someting else to investigate.I can overide the system to put heating on but would have to leave it on all day setting?
yes i think you will need to re-establish rf contact between the sensor and scr unit
Went through the recommissioning instructions,the receiver seems to work,switched boiler on and off etc but it doesnt appear to get a signal from the sender stat,would this be a replacement stat (its about 7 years old),are they available separately or do you need to replace both units?
Both units pal, as the frequency has now also changed.......
Reply to the thread, titled "Drayton digistat" which is posted in UK Plumbers Forums on Plumbers Forums.
ceabhail,
Nostrum,
