View the thread, titled "Drilling holes in bath for taps" which is posted in UK Plumbers Forums on UK Plumbers Forums.
C
Curlyworld
Hello
I have to drill some holes for a mixer tap in a plastic bath, which is a first for me. I have only got a bog standard hole drill set. Does anyone have any advice for doing this job?
place masking tape around the area you are drilling
start slow and keep your nerve and a steady hand and it will be fine
not too much pressure let the teeth do the work and remember to ease off when nearly through
Many thanks for the advice. Don't suppose you know what the measurement between the centres of the holes should be on a standard bath?
It depends - best to measure the taps when you have them.
Also, when drilling, as said above, slow and steady. For the first hole you can use a tiny drill bit (around 2mm) as this will help keep the tip of a larger drill bit straight and prevent slipping. It also gives you the opportunity to measure again and make another hole if one of the first ones is in the wrong place.
Draw round the taps on paper,then find the center,tape paper onto the bath then drill
Followed your advice but first did a test run on a bit of wood to make sure my centres were right. All went perfectly, thanks peeps.
Reply to the thread, titled "Drilling holes in bath for taps" which is posted in UK Plumbers Forums on Plumbers Forums.
