View the thread, titled "dripping overflow pipe" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Hi guys,
I know this has probably cropped up a million times before but... overflow runs occasionally when heating is on ( vented system ). I changed the ball valve in the F&E tank as is was ancient and in a bad state - also lowered the water level in the tank by a couple of inches but not sure if this will do the trick. Any other solutions?
cheers
dave
turn stat down on boiler,make sure water level not to high in jockey tank,bale it out,check b/v water inlet level not to high,this tank allows for expansion of water
Hi. Asalready said. But if it continues? Isolate mains to cistern and monitor water level, if is continues to over flow it may be a coil in cylinder problem.
Reply to the thread, titled "dripping overflow pipe" which is posted in UK Plumbers Forums on Plumbers Forums.
