N
newbie1
Hi following on from another thread have decided to invest in a dry pipe/air pressure tester and have looked at
1/rothenburger
2/regin
has anyone used either
the regin is in a kit 135.00 and rothenburger about 65.00
just a quick question how long does it take roughly to pressurise say a 7 rad system with a combi with air using one of these or a cheap b@q compressor and do you do the same as with water ie fill and bleed a bit or just pump it up to about 2.5bar
please no replies about why or when etc just some informed info about how and method and time taken etc as i would rather spend 15mins testing with air than 2 hours clearing up water and then either cutting out a joint or smothering it with flux and blasting it toget solder to run again
thks
migo you seem to use these so please pipe up(exuses the pun)
1/rothenburger
2/regin
thks
