Guest viewing is limited
Dudley Niagra replacement
View the thread, titled "Dudley Niagra replacement" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Morning all, I have another problem I’d like some advice on please.
wifey has a concealed cistern with a pneumatic Dudley niagra flush mechanism. I changed this a few years ago because the pneumatic mechanism failed and it’s failing again. I recall that the whole mechanism simply untwisted from the base unit and was very easy to replace.
if I install a mechanical cable operated flush would the replacement be as straightforward or are the base units incompatible?
thanks in advance
You maybe lucky if you can source the mechanical valve below the cradle which supports the flush valve body look very similar ?
Reply to the thread, titled "Dudley Niagra replacement" which is posted in UK Plumbers Forums on Plumbers Forums.
GaryHope,
king of pipes,
