View the thread, titled "Easiboost shower pump." which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
Poppy64
Hi everyone, this is my first attempt at this so bear with me! I have an Easiboost shower pump that's been fitted and worked fine for approx 8 years. It's recently started to not pump the hot water through. The pump is running but the water is only tepid. Is there a general service I can do on it or is it on its way out. Thanks.
If the pump is running but the water is only tepid then it could be a fault with your thermostat cartridge in the shower rather than the pump!
Put your hands on the feeds into the shower, if the hot supply is hot but only coming out cold then you require a new thermostat cartridge...
Reply to the thread, titled "Easiboost shower pump." which is posted in Showers and Wetrooms Advice on Plumbers Forums.
