View the thread, titled "elec shower, help please..." which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
C
cammy22
Hi. I'm installing a new shower. Bottom left with rear entry. I have 10mm pipe coming from tiled wall, blanked. Inlet is plastic 15mm. Today I bought 10mm comp elbow, 15mm comp elbow and a 10x15 feed end reducer. I thought this would work. Now I see reducer won't fit the elbows? Please can you guys help...
Thanks in advance...
What made you put 10mm out the wall?
would have thought them reducing fittings you put in compression would have worked to be honest! sure you put it the right way around?
Out of interest guys - why would 10mm be a problem?
The flow rate of an electric shower is puny at the best of times - maybe 3 or 4 litres a minute, absolute tops?
I would have thought that a mains fed 10mm pipe could easily manage that, with flow to spare?
Some electrics showers give 7 liters + pm. when you have it ramped up to high the flow rate suffers and some showers can go to high temp lockout, especially if someones flinging mud then flushes the cludgy 😉
Ray you hurt my head from time to time - what you say seems to make sense
but ....... we always do lecky showers in 15mm mains fed Jon help me CHK QUOTE=Ray Stafford;662435]Out of interest guys - why would 10mm be a problem?
I would have thought that a mains fed 10mm pipe could easily manage that, with flow to spare?[/QUOTE]
You may get away with 10mm but 15 is standard rule of thumb. (right way) showers now will give u a min press to adhere to instead of flow rate . Use a 3 piece compression reducer inside a 15mm compression bend . If your cold main has good enough pressure it may suffice . Only thing 10mm should ever be used on is gas fires. ( just my opinion)
yeah i see it should be 15, i have no idea why he used 10. cowboy.
But the thread isnt about the fact its 10, its about how to connect the 10mm pipe to the 15mm inlet. What is this 3 piece reducer? is it this...
travisperkins.co.uk/p/compression-internal-reducer-15-x-10mm-dzr/950051/3961030
7 litres per minute, even on a 10.8kw leccy shower would only give a temp rise of 16 degs. At a sensible rise of 35 degrees, the flow rate is only just over 4 litres per min. And thats a 10.8 kw shower - adjust down for 9 or 8 kw.
and surely most showers come with a flexible hose with a bore miles less than 10mm, which makes the inlet bore somewhat moot?
I can see words here, but would appreciate them transalated into English ? 🙂
10mm feed to instantaneous. Then you're reducing it again with additional elbows.
If it were me I'd put 15mm before ever thinking of turning on the shower. Sure you may Experience surge in the main water feed @ high demand times. Boshboshbossboss
Reply to the thread, titled "elec shower, help please..." which is posted in Showers and Wetrooms Advice on Plumbers Forums.
