View the thread, titled "Electri shower witha mind of it's own!" which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
Sgt3355
Hi
I have a problem that has me beat I have to admit. I have a Mira Sport electric shower fitted. It has been in use for some 10 years, probably a good tad more without a problem. That is until recently, when it often would not produce a water stream, merely a dribble. Assumed it was at “end of life”, but before I bought another I cleaned and overhauled it (not much to that and all appeared in good order). Put it back together, no change but did find that if I run the hot water supply (via a combi boiler) and then turn the shower on, it will pick up and work (& still does). Any ideas, the combi (Worcester) has been in use just slightly less than the electric shower, i.e. about ten years.
Regards Rick
A very good question, cos this thing has worked perfectly for years. This is a fairly recent "occurrence". It may just be coincidence; I simply don't know. It may have something to do with pressure maybe, in fact I have just tried to use it and my system (hot water tap etc) failed totally, so what do I know. As far as I can tell these electric showers are driven merely by mains pressure i.e. no pump, and the temperature by restricting the flow; simples as it says in the advert. Maybe it's me missing something?
unless im reading it wrong but a combi will not effect your electric shower as the shower only has 1 feed and that should be mains cold. unless you have a electric power shower with a hot and cold feed
it may well be effecting it since your combi is mains fed, so your losing pressure/flow rate at the shower and giving it more of a chance to heat up the water, i'd say your shower is near the end of its life
I think you're right; it's just yet another job I would rather have put off (for months); though never mind I suppose the bathroom could do with re-tiling! Thanks buddy
Regards Rick
i'm assuming you mean that the shower only works when you have a hot tap running, if so then yes it would be because the pressure/flow rate has reduced and the water has more chance to be heated.
That's life for ya mate, throws problems at us when we dont want them lol
That being the case could it have something to do with the pressure setting on the combi?
I had some building work done not that long ago and the combi did need adjusting when it was serviced, or am I grabbing at straws?
nothing to do with the combi, its your mains supply. You could try and reduce the flow rate of the stop tap by turning it down, but I think your shower is on its last legs, this could be a temporary fix but will result in reduced flow rate at all outlets.
I have to agree the shower is at the end of it's days. Pity, it's a job I would have rather put off for a bit, but on the positive side the bathroom needed re-tiling! In fact I've just reduced the flow and had a lovely hot shower to end the day!!
Thanks for all the advice
Regards Rick
Reply to the thread, titled "Electri shower witha mind of it's own!" which is posted in Showers and Wetrooms Advice on Plumbers Forums.
