View the thread, titled "Electric boilers" which is posted in Boiler Advice Forum on UK Plumbers Forums.
stupid question time
Is there a electric boiler out there that will heat underfloor heating but also provide water to taps without the need for a storage tank of some sort ??
Yes, you can get electric combination boilers.
For a decent flow rate, they use quite a bit of power/amps. Will need to check your main supply can handle it before pulling the trigger.
Reply to the thread, titled "Electric boilers" which is posted in Boiler Advice Forum on Electricians Forums.
