View the thread, titled "electric shower for cold from a tank and hot from combi" which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
danny_090
can anyone recommend an electric shower which can accept cold from a tank and hot from a combi. I know about the pressure difference but just seeing if theres any
this is a pumped electric shower. it was run of a cylinder and tank but she had a new combi and it started leaking, do I get the same one or different
The pumped ones do. Feeds need to be balanced. I.e unvented and cold headder . Don't fit an electric one u twonk ! Thermostatic mixer!!!!
(Vented)
Sounds like a pumped shower that's been left in after a combi install. Needs either an electric off the cold mains or a shower valve off the mains hot and cold.
OK, I understand now, not an electric shower at all - except in the sense that the integral pump needs power.
No, I dont think any of the integral pumped units will be happy with high pressure on either side.
Why not just use a thermostatic mixer and run the cold main to it as well as the combi fed hot?
only problem is there missing a tile where the shower was and the pipes are located next to each other, small job turning into a big one
Unfortunately, yes - but the job was created by whoever put the combi in, not realising that it would mess up the shower.
This story has a ring of familiarity about it. I seem to remember a member of the public coming on and getting the same diagnosis a couple of months ago. Wonder if its the same job?
exactly the same as what I have here. I didn't know it was tank fed until I turned the water off and it still came out. I will get a thermostatic mixer and surface mount the pipes hopefully they don't mind as it doesn't look nice but its better then ripping tiles off
Reply to the thread, titled "electric shower for cold from a tank and hot from combi" which is posted in Showers and Wetrooms Advice on Plumbers Forums.
