Electric to Mixer Shower
View the thread, titled "Electric to Mixer Shower" which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
Hi All,
I currently have an electric shower fitted which gets extremly hot and is forever burning out the fuse switch outside the bathroom which I reguarly need to replace. That combined with fact that the pressure is OK but as we would like a good powerful shower, we are considering a mixer shower?
Is this the right route or could we stick with an electric shower but install a pump?
How simple would it be to install a mixer shower? Am I right in thinking all we need is a hot water supply to the shower location and that is us? Then there be no need for a fuse switch or electricity and the power would also be better or would even with a mixer would we still require a pump as well?
Any advice/guidance would be appreciated!! Also be good to see some of your set ups if you have photos or drawings of previous jobs!
If the shower is "forever burning out the fuse switch" then it was incompetently installed in the first place and needs to be checked and sorted out by a qualified electrician. It's only a matter of time until your present arrangement burns your house down or electrocutes someone.
This is fitted with a 45A Switch, this is what will burn out eventually. Not straight away but over time. I've always thoguht it was just the switches which were poor quality. This part always goes before the MCB on the board goes as you'd expect. The Shower is a 10.5KW electric shower so I have no idea why it would burn this out.
IMO, the switch is under-rated for a 10.5kW (44A @ 240V) shower. My guess is that the cable will be underated as well, should be at least 10mm. Showers need to be protected by an RCD or RCBO not an MCB. Wiring impedance ("Z" values) and earthing integrity need to be checked by an electrician using the proper kit.
@Murdoch - this is your domain, have I missed anything or got it wrong?
I like Hager products, e.g.:
but you should really get an electrician to check the installation, particularly the sizing of the cable and the earthing and bonding.
OK thanks I will.
My issue was I already had a switch on outsdie wall so would like keep that rather than a pull down cord if that was possible, anyone know?
Can I also ask about the set up? I have a combi boiler with only cold water supply to my electric shower. As I'd like a more powerful shower, can a pump be fitted and/or am I better fitting a mixer? What's my options? Any advice?
Reply to the thread, titled "Electric to Mixer Shower" which is posted in Showers and Wetrooms Advice on Plumbers Forums.
Mcknze21,
Mcknze21,
