View the thread, titled "Electrical training" which is posted in UK Plumbers Forums on UK Plumbers Forums.
P J F PLUMBING
Hi guys I'm having big problems getting a leccy so was thinking of just training as one the basics ect maybe changing fuse bords ect is this hard to do ?? Cheers Pete
I think that Keiran did it (Cr0ft).
One of my lads who was 10 years on the plumbing tools, and now works in our shopfitting crew did the training and got the quals, but found it very hard. At the end he is OK for small works, but we still bring in a "proper" sparks subby if its anything complicated.
I'm looking to do works like fuse bords electric showers ect more work ect
I thinks its like plumbing Pete.
P1ss-easy ... until something goes wrong. Then experience counts.
I do minor works I just want to remove the middle man and just do it myself
Been well worth it for me. As Ray says, it's easy getting signed off to do it really. It's the same training to get fully qualified for defined scope as full scope, the only difference is your 2 assessment jobs. Change 2x consumer units and be assessed by the registration body on them and you can be a full scope electrician. Rather scary I know but that's the deal.
Like Ray says, electrics is quite easy when it goes well. When you get a call like I had the other night because the downlight connector block has melted because the customer has put a box on top of the fire hood, doesn't half scare you though!
That is the only callback I have had in 2 years of electrical work though. You don't get many callbacks at all doing electrical work, not compared to plumbing.
Should say, the training is quite hard, well the 2391 inspection and testing exam is. Quite a high fail rate on it. That's the one you need to sign off your own work.
i will be doing it in the next few years. i like getting my teeth into everything.......
gas safe and oftec at 21
i want to be a qualified spark by 25 i hope 🙂
Corgi have lower standards than a lot if the other self cert companies no need for inspection and testing ? Or so I am informed ?
do u need the full qualifications? or can you just do part p course?
The qualifications are the same to do both, i.e. 17th Edition Wiring Regulations certificate. The inspection and testing is the bit you either need to know how to do and how to interpret the results or do the course on it to learn it. If you are going into it with limited prior electrical experience then the 2391 is well worth doing as well as it will give you a lot more knowledge and understanding when you start charging customers!
If you just do the 17th Edition Wiring Regs and fit a consumer unit it would be like me fitting a gas boiler and because it all seems to work assuming it does basically (I don't do gas).
The only difference between defined scope (what you call part P) and full scope is the assessment jobs you show when you join NICEIC or ELECSA etc.
In other words, replace a couple of family member's consumer units, do the 17th Edition wiring regs and 2391 Inspection and Testing course and you can call yourself an electrician.
As with plumbing, in my opinion, it's the fault finding where you need the experience on the job. Installs are relatively straight forward.
It's a requirement to issue a test certificate with most electrical work, so without the 2391 or previous testing knowledge you are going to struggle to do that.
The test meter is around £600 for a decent one too and it has to be calibrated annually for around £40.
Hope this clears things up.
I was told by Brian Scadden, that 2391 not necessarily needed for registation onto a scam, sorry scheme.
As long as you have a level three qual, ie the 17th wiring regs, AND can prove you can test competently, then you will be accepted onto a scheme.
I did the 2391, as have a lot of customers who have industrial units, so a lot of three phase.
Dont think the 2391 exist now, think they split it up into initial verification, and periadic testing.
Definitely worth getting, if you think you will get the benefit out of it.
For me now it is pretty much a fifty fifty split in gas and electric work.
Good luck.
I'll come live with you, you teach me the way of the spark and ill help you get your gas safe?
*grins*
If you are with ELECSA, they are happy for you to buy a calcard, at £20, and test once a month against this. As long as it is recorded for inspector to see, then no problems
*grins*
I would seriously consider that one tbh. I am desperate to get my gas quals. So much so I am even starting to look at courses that I know are a rip off just to get my ticket as no one round here will help get it!
That I didn't know. Thanks a lot!
Like we said before shame were just that bit too far apart
After march i will be going on my own gas safe registration. So if you could source a few jobs in the summer i would be willing to come up 🙂
post up in the arms for members to buddy up with if you source the work.
you could get away with family members houses tbh
Getting work will be no problem as long as I can put on Checkatrade the details of the firm that will be doing our gas work for us until I'm qualified, i.e. their GSR number etc. Checkatrade is where I get most of my work and they obviously want to make sure a qualified gas fitter is doing our gas work.
If I just want to fit domestic boilers what is the portfolio requirement needed? I am a bit confused as I get different answers from training centres to gas fitters!
I have no idea what you require tbh, i did mine as an apprenticeship.
If you haven't got it done by the summer then ill come up 🙂
as you wont be competition 😉
Just a word of warning. The electrical requirements has now changed since April this year. There is a requirement for either you to have undertaken the NVQ level 3 or this new supervisors course. I have 17th, 2391 and full scope part P but cannot join a CPS as I do not hold either of these.
The supervisors courses is about £900+ vat and is a portfolio type jobbie so site visits and a week course. I've no interest in it now as heating controls are no longer notifiable and anything bigger gets subbed out.
Just thought you all might want to know as if you go spending out on 17th edition or test and inspect alone, you won't be able to self certify notifiable work.
Personally I found 17th edition left far to many questions unanswered. I did 2391 to further my knowledge. Its hard going being able to stay on top of it all if you don't do it much to be honest. I've forgotten a lot of the basic stuff which is annoying as I was on the ball on the run up to 2391. I think the new test and inspect is a lot easier as well.
Good call, completely forgot about that
Reply to the thread, titled "Electrical training" which is posted in UK Plumbers Forums on Electricians Forums.
