All I need is a way to seal (water tight) the end of a short length (30”) of plastic tube-just like the WP26 fitting in the photo, but a larger diameter, maybe 60- 75mm dia (round or square). I have done it with a 110 push fitting, but when this size pipe is filled with water it is quite heavy to move at this dia /water capacity.
Although they are plumbing fittings and holding water, the end use is not for plumbing. Any ideas/suggestions? I have failed to establish if there are any fittings on the market (around the dia that I require). Willing to buy from non-UK source if that is the only option. Only need 2 fittings.
