Here's a few questions for those in the know on these units. I've only had a brief look at these after reading a couple of other posts on here.
Just to reinforce what I think I know, the unit extracts warm air from house via ductwork and uses that heat to generate hot water.
What volumes of air do these units extract? and i take it make up air is from outside through vents?
So in winter you are sucking out warm air and replacing with cold, therefore needing extra heating within these rooms?
Do the units run continuously? i.e overnight.
If the units run through the day could you have ductwork into roof space, say on temperature controlled damper. Very warm in loft space when suns out, lost many a pint or two in sweat working in attics etc.
Whats the recovery rate like? What back up / top systems can you have, immersion, boiler?
What size ductwork is required?
Questions, Questions, Questions!
Whilst I'm on who has the best unit, and which would you fit?
Simon.
Simon.
