M
mike
Hi, today i had to remove the expansion vessel on my oil combi boiler inorder to change a auto air vent which is leaking, i took the opertunity to rechardge the expansion vessel so i drained the system then the expansion vessel out (the water side) and discoverd there was still some water in there but in the air side! so i turned it upside down (the schrader valve is on the top) and drained the air out and the water came out about about 20ml, the thing that confused me is that the system worked fine pressure has never risen above 1.5 bar and the vesel air pressure never drops.etc so should i replace the vessel or should i just keep using it .
