J
jddevel
What is the ideal location for an expansion tank in a sealed system and is it best off the flow or return to boiler.😕
Thanks Puddle. Now I`ll expand ( excuse the pun).
Due to a catalogue of errors based on a local so called plumbers advice I`ve ended up with a Grant Vortrex 15/26 kw system boiler. ( I started with a non system boiler -same size, was then told it was inadequate although our calculated heat loss was only 12kw max. as it would not run the ACV 300SLE heat store properly. So a 58/70KW was ordered. ON arrival of this HUGE thing and the "disappearance" of the first plumber two others were asked to quote they visited but didnt do so and two others I`m still waiting to see!!!!!! SO I`m dealing with as much of it myself until someone "turns" up.
Checking with ACV and Grants it turns out the original boiler was quite sufficient but then sods law instead of delivering a non-system you`ve guessed it a system boiler has arrived.
My intention is therefore to add a further 35 ltr expansion tank on the return to boiler to supplement the 12 ltr tank in the boiler. As the system boiler has provision for pressurizing and safety valve etc this should be a simple task.
Now further advice needed. The boiler is to supply the following:-
First circuit The underfloor heating- two manifolds (18 circuits) 160 ltrs
Second Circuit Four towel radiators and a standard radiator (2600btus)
Third Circuit The ACV 300 SLE
The boiler has its own pump (as stated system boiler) and I would like to control all three circuits separately. My leaning is to a Y plan with two port valve to the ACV and a three port to the towel rails/radiator on one port and the underfloor on the other thus giving me seasonal control. Is this possible or would a S plan be bettetr. What conflict will another pump creat or should I just upgrade the system pump as I fear it will not be adequate to run all thats required 1590 mtrs 16mm under floor the Heatstore and whilst small the towel radiators.
Sorry this is a bit long but advice please.
Reply to the thread, titled "Expansion Tanks in sealed system" which is posted in Central Heating Forum on Plumbers Forums.
