Expansion Vessel Question
View the thread, titled "Expansion Vessel Question" which is posted in Central Heating Forum on UK Plumbers Forums.
Q
Quiz
If I wanted to remove my F & E water storage cistern and replace with an expansion vessel kit.
Am I right in assuming that the kit will come with a water feed loop that can be connected to the redundant F&E supply.
If So, could this feed loop be used to periodically flush through my rads and reduce the need to ever have a Powerflush?
I guess that a kit would also have an over pressure relief valve?
Hi Although you are replacing the F&E with an expansion vessel, in my experience the vessel is fitted close to boiler and existing vent, cold feed and main supply are cut back and capped off.
Reply to the thread, titled "Expansion Vessel Question" which is posted in Central Heating Forum on Plumbers Forums.
Quiz,
justlead1,
