Hi
I have a Grant 26-36 S Pro boiler fitted with underfloor heating and DHW. The system was fitted about 3 years ago (not by me) and has worked well since then, only issue is topping the system up every now and then. Pressure has never fallen sufficiently to stop the system working I have just noticed the pressure has dropped and topped it up.
Anyhow I have been looking to flush with F3 and add F1 to the system as I don't think this was ever carried out and was doing some calcs to find out the system volume and came up with 300L of system water (boiler, DHW, 3 x towel rads and 400 Sq M of underfloor heating).
The system only has a standard expansion vessel fitted of 12L. Obviously this is way undersized and probably the cause of the topping up although I have never seen high pressure in the system.
I am looking at increasing the expansion to 24L and the obvious way would be to add an additional 12L vessel which seems to be standard practice when more expansion is required. However is there any reason why I shouldn't remove the existing 12L vessel and add an external 24L vessel? I could use a long SS flexi to tap into the system at the existing expansion vessel point.
Does that sound like a good plan?
Any help or suggestions appreciated.
