View the thread, titled "Extractor in toilet room?" which is posted in Boiler Advice Forum on UK Plumbers Forums.
T
Tubbyewe
Afternoon all.
New sink and WC being added to attic room. No shower or bath. This "room" will not have a door as such but a curtained doorway (that's what she wants!) into the rest of the attic. The attic has a window that can be opened.
So do regs say I need an extractor fan?
Why try to avoid adding one I hear you ask? Just do it anyway.
Building is listed and extractor will need to go through roof, requiring a longish run and a roofer so extra expense. Cheers.
If you have big enough soffits, box the vent pipe down the wall and exit. Failing that get a roofer in to add a prescribed vent through the tiles. Failing that exit into the bedroom below 90 degree exit to hole drilled in wall. You can get a 100mm core drill.
They used to make condensing extractor fans, can find them any more.
Listed building, god help you.
Reply to the thread, titled "Extractor in toilet room?" which is posted in Boiler Advice Forum on Electricians Forums.
