View the thread, titled "F & E Tank" which is posted in UK Plumbers Forums on UK Plumbers Forums.
L
Leoki
Hello, i was in my loft the other day and took the cover off my F & E tank. The water in the tank has Fernox MB-1 in it but on the top of the water, at the edges of the tank i have what appears to be mould growing in small patches.
Is this normal as the water is mostly stagnent ?
Should i add anything else to the tank to get rid of this stuff or is it okay ?
The system was washed through last year.
Just clean out mould if you wish,should not happen again if lid fitted tightly,it can happen once chemical applied to a system, previously with non,as chemical keeps system clean put also kills any life that had developed previously in and around tank or upper pipework,this floats to the top
Reply to the thread, titled "F & E Tank" which is posted in UK Plumbers Forums on Plumbers Forums.
