Fair price for replacing shower tray and surround?
View the thread, titled "Fair price for replacing shower tray and surround?" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
Hi all,
Have had a quote to rip out existing tiling (due to water ingress), replace the shower tray and replace tiles with plastic wall panels.
This is a small ensuite, approx size 70cm x 80cm x 170cm high.
Quote is 2k and a week to do. Does this seem about right for the job?
Not the tray, that’s extra!, 2k for enclosure once you go 10mm minimalist it’s easy to spend spend - I’m not saying it’s worth it, just you can spend it!
Oh arrr, so it does RPM!
I also see it says 700 x 800; now I’m thinking that (almost) no matter what it seems too much - however it is all too vague, see what spec. Is when OP comes back.
Glad we`re on the same page, seems high atm, Hammers lives that way I believe, wonder if he would like to chip in
Depends what you find when ripped out, if it’s been leaking it may need reboarding and skimming, or bonding and skimming depends on the walls, plus floorboards may be shot too.
Hi all,
yeah, that sounds a lot
For me plastic is a no go. Even the 10mm I've seen is terrible. Panels for me have to be Grant Westfield or Mermaid.
Oh I'd never recommend them either, I like nuance bushboards and will always recommend them over any. I've had trouble with mermaid so won't use those either.
Reply to the thread, titled "Fair price for replacing shower tray and surround?" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
Pinky,
king of pipes,
